canon C2020 error code E025-0200
  • markndreu
    • Mar 2014
    • 34
    can you help me
    I have clear all hopper cyan
  • ernesto
    • Oct 2011
    • 430
    Re: canon C2020 error code E025-0200
    Originally posted by markndreu
    can you help me
    it seems fine work.....
    E025 0200 05 Title Toner Supply Motor (C) lock detection
    Description After turning ON the motor, the rotation sensor does not detect
    although a specified period of time has passed.
    Remedy Overload of the motor or motor failure
    1. Check conduction of FU9 on the DC Controller PCB (UN09).
    2. Check the harness/connector between the DC Controller
    PCB (UN09/J24) and PS08.
    3. Replace the DC Controller PCB (UN09)
    4. Check the Hopper Unit (C).
    5. Replace the Hopper Unit (C).
    I think that cian hopper unit is the problem.....
    • rayjeek
      • Jun 2010
      • 239
      Im my case it was E025-0100 last week on IRAC2020 as well. I vacuumed the Magenta hopper and replaced CYM drums which were much over life (215%) to resolve problem.
      However, resolution from other post for this problem was to replace cable harness from DC controller to the Toner feed assy.
      Good Luck and feeback!!
      • ss12
        • 289
        Another thing that can cause this issue is the drum holders which have been modified.There is a bulletin regarding these error codes
