Canon Advance C9075 error E004-0101, please help me
  • digitalpressvietnam
    • Jun 2012
    • 51
    My machine got error E004-0101 when power up. I replace DC board but still error. I also replace fixing unit but no change. Please help me
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4998
    Re: Canon Advance C9075 error E004-0101, please help me
    Damaged fixing lamp cable.
    • Dutchman
      • Jan 2011
      • 58
      Be sure to clear the error in service mode: Copier - Function - Clear - Error
        • Jun 2012
        • 51
        I clear ERROR in service mode but not change. I saw the temperature of fixing increase up to 130 degree and then decrease. Monitor display error code E004-0101
        • darryl1965
          E025-0402
          • vigour
            • Aug 2010
            • 1038
            I am asking you again
            Do you have the right voltage
            The C9065 was plugged into a NEMA 5-20P outlet with only 120 volts on it. The C9065 and C9075 require 208VAC from a NEMA 6-15P outlet.
            • vigour
              • Aug 2010
              • 1038
              Originally posted by darryl1965
              E025-0402
              Your black hopper has issues.
              Usually soiled sensors leading to the brass bushings jumping out of place, because the metal is so flimsy
                • Jun 2012
                • 51
                My machine buy from USA, use power 110v
                  • Jun 2012
                  • 51
                  I changed power to 120V, it's ok. Thanks so much
                  • vigour
                    • Aug 2010
                    • 1038
                    The C9065 and C9075 require 208VAC .
                    7055 and 7065 requires 120v.
                    Did you exchange fusers between 9075 and 7055 ?
                    THE LOWER LAMP IS DIFFERENT.
                    YOU WILL END UP WITH STRANGE E CODES
                    You keep opening new threads for your 2 Advance machines.
                    It is getting confusing, to figure out the issues
                      • Jun 2012
                      • 51
                      Thanks so much for all
