Canon iR8500 copy from black to white
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    [Misc] Canon iR8500 copy from black to white
    The original copy is not clear, I have to wash tank and replacement ink toner titles. When making copies, the images appear very pale. In service mode *28* copier >> function >> install >> toner-s. It is the same. I made clear by the function >> clear >> dc-con, r-con, service, cnt-mcon, cnt-dcon and adjust ccd new and set the standard again. It is the same as. How do I solve this problem?canon003.jpg
  • teckat
    • 16083
    Re: Canon iR8500 copy from black to white
    Originally posted by phollawat Chaimoonchuen
    The original copy is not clear, I have to wash tank and replacement ink toner titles. When making copies, the images appear very pale. In service mode *28* copier >> function >> install >> toner-s. It is the same. I made clear by the function >> clear >> dc-con, r-con, service, cnt-mcon, cnt-dcon and adjust ccd new and set the standard again. It is the same as. How do I solve this problem?[ATTACH=CONFIG]28841[/ATTACH]
    Looks like a reverse image=inverted
    White fonts on black background_????
    • davidj7
      • 1107
      looks like loss of bias in the developing assy.check that . unplug and plug again the DC PWB and MFC pwb
      a machine is only as good as your tech : source:screwtape ; the scary one
      • markndreu
        • Mar 2014
        • 34
        change primer corona
          • Dec 2007
          • 71
          Thankyou very much. I Check again.
          • شهد دمى
            شكرا عل الموضوع
            • teckat
              • 16083
              Originally posted by شهد دمى
              شكرا عل الموضوع
              ترحيب
              • wassem
                • Aug 2012
                • 166
                the reason for this problem is using toner ir 5000 in ir 105
                • teckat
                  • 16083
                  anything is possible//////////// seen customer spoon feed XEROX Toner into old NP Canons
                  • davidj7
                    • 1107
                    "anything is possible//////////// seen customer spoon feed XEROX Toner into old NP Canons "
                    hmm and i thought i was the only one having problems :-)
                    • tinnyjay
                      • Oct 2009
                      • 663
                      I've seen this before and it happened by using bad toner and only after vacuumed developer unit and started using oem toner, got back to normallity.
                      Its called "negative" image
                      "Who loves the roses,must also bear thumbs"
                      • zoraldinho
                        teacher-guide-expert-guru
                        • Mar 2008
                        • 5007
                        Originally posted by teckat
                        ترحيب
                        ليس هناك أى مشكلة
                        • Brian G
                          • Mar 2015
                          • 21
                          Did you try swapping out the laser assembly?
