Canon ADV-iR C5045 - RUI ?
  • kuby
    • Oct 2007
    • 1396
    Have one that will not bring up the RUI from the computer. It is turned on, and the copier version says 75.01, but....the computer when I try and access the Address Book or something says 79.01, also when I do a P-Print the RUI is --.--. Do I just need to reload the RUI?
  • SAZ911
    • Mar 2013
    • 193
    Re: Canon ADV-iR C5045 - RUI ?
    Hi Kuby,
    I would recommend you upgrade to the latest firmware including "RUI" and you should be good to go. Since you need to upgrade your "RUI" you may aswell do all the firmware.
    Cheers,
    SAZ911..........
    • Brian G
      • Mar 2015
      • 21
      If after doing the full firmware upgrade and it still doesn't work try doing an MMI Clear. This will wipe out all your network settings and some others but I have had good success using this for weird problems. Good luck!
      • kuby
        • Oct 2007
        • 1396
        The firmware is up to date.
        Originally posted by SAZ911
        Hi Kuby,
        Cheers,
        • SAZ911
          • Mar 2013
          • 193
          Hi Kuby,
          Have you upgraded since the problem started, (your rui firmware may be corrupt), also as mentioned above an mmi clear does help with silly issues, cant say for certain that it will for this issue, but since you mentioned that rui isn't listed on your p-print, its probably worth trying to re-install.
          cheers,
          SAZ911..........
          • teckat
            • 16083
            Security settings could be blocking RUI.
            But since u don't see RUI in print out, reload.
            Remember_RUI must match Language ver.
            Main_79.04
            Language_79.04
            RUI_79.04
