SMB scan to folder-password change
  • MunsterTech
    • Sep 2014
    • 381
    [Misc] SMB scan to folder-password change
    hi guys,
    Ive seen a post like this before, but cant find it now.
    Set up a Canon IRC250i on the network today, each user having a scan to folder on their desktop. I was told after that every 3 months, the users password on the workstation, needs to be changed. As you can appreciate, this will then stop the scans being sent from the host to the users workstation.
    I have seen a post, some while back that there is a setting that will overcome this issue of password changing and scans not working until the updated password is set into the copier again. Anyone help on this?
    tks
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: SMB scan to folder-password change
    From a general networking pov, if the users are local you can use Run > lusrmgr.msc and create a new user whose password never expires and use that for SMB scanning, as long as they are running Windows 7/8 Pro or higher and are administrators. If the users are on a domain then you can use: https://msdn.microsoft.com/en-gb/lib...=cs.70%29.aspx
