Mf 9170c Has E00001 code
  • jake24482
    • Apr 2011
    • 116
    HI
    every body
    I have mf9170c machine popping E000001 code can some one give me any detail on this code or let me know what causing it .is it fuser or power supply .
    Thanks an advance
  • teckat
    • 16083
    Re: Mf 9170c Has E00001 code
    Originally posted by jake24482
    HI
    every body
    Thanks an advance
    Remove fix unit_check sleve conditions.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      It's overheating.Probably bad fixing sleeve unit.If you have sub code 0000 then main thermistor detect overheating.Sub code 0001 is the status where the detected temperature of the sub thermistor is overheating.Of course also can be DC.
      • jake24482
        • Apr 2011
        • 116
        i did check the sleeve it is kind of bad from side .
        • jake24482
          • Apr 2011
          • 116
          is it same procedure to reset the code an ir series or some other way
