Adding toner thru service mode IR3225
  • Brian G
    replied
    Re: Adding toner thru service mode IR3225
    Copier->Function->Install->TONER-S in service mode. You run this at the time of installation or when replacing the developer unit. It adds toner and stirs at the same time. It starts out with a 600 second counter but can terminate anytime during that if it has the developer unit setup properly.
  • ernesto
    replied
    Originally posted by yormets
    I am trying to figure out a lack of toner in the machine. The DV unit runs low on toner, however the machine never asks for any. I've changed DV units but got the same result. It takes a couple of weeks before the machine before the DV runs low again. I was searching for a way to determine what is actually wrong. As you can see I have been playing with this for months now. With all the info I have been given, I believe I will finally determine what is actually wrong. I believe it may be a toner hopper problem. I wanted to see if I could physically add toner through the service mode. If I can than it is probably a sensor issue.
    this link could be useful too
    http://www.copytechnet.com/forums/ca...ing-toner.html
    You can open the toner cover just a little bit to check if the bottle toner is turn around..........what happen with it?
  • yormets
    replied
  • ernesto
    replied
    Where is the "add toner" code in service mode? I can find toner stir, toner motor, and hopper motor. Which ones adds toner to a new developer unit? I must be blind.
    Roy
    why do you want to add toner from service mode?
    All the best
    http://www.copytechnet.com/forums/ca...ht=add%20toner
  • yormets
    started a topic Adding toner thru service mode IR3225
    Roy
