IRC 5180 / E751-9000
  • Ronald Canon
    • Dec 2011
    • 30
    [Error Code] IRC 5180 / E751-9000
    Hello everybody i have a problem with a IRC 5180, E751-9000. I changed the 4 toner cartridges and the 4 drum units but the code still appears. What could it be the problem ?. Thanks for the help...
    Re: IRC 5180 / E751-9000
    Error :
    The copier displays E751-9000 at power on.
    Workaround :
    Slide out the bypass assembly and check the internal connector J750 and the bypass connector J755 for damage.
    If necessary, replace the damaged connector.
    • teckat
      • 16083
      happens from customer slamming in bypass unit, especially when printer is installed in a tight/poor accessible location
      i always blame salespeople on this one; by taking pics of where they tell customers a printer can be installed-----------
