PDF problems LBP 6780x
  • Manxengineer
    • Jul 2025
    [Misc] PDF problems LBP 6780x
    hey guys and gals,
    I have recently just installed a new 6780x, however ive kind of hit a bit of snag with printing from a PDF file. The main snag is it just doesnt print at all. However I also tried to print it to the iRAC 4235i and it printed no issue. It seems like a font problem but i'm curious to know if there is a fix to this issue?
    has anyone else run into this problem?
    Kind regards
  • teckat
    • 16083
    Re: PDF problems LBP 6780x
    Driver
    PCL5e/6, UFR II, PostScript 3, PDF, XPS
    Change the text format.
    If you are connected to a printer over a network, then connect the printer directly to the computer.
    If the file prints correctly, then network-related issues may be the cause.
    • Manxengineer
      I found that de-selecting all the colour management options in the PDF Print options cures this error. Cant be certain this is the correct fix but a fix none the less for now!
      • teckat
        • 16083
        Yeah, that's the fix, forgot about that pdf color
        Management option.
        Good find
        • Manxengineer
          Management option.
          Good find
          Thanks, just done a little trial and error scenario in the workshop and bingo ! Enjoy your weekend
