ir1730 load paper
  • ernesto
    • Oct 2011
    • 430
    ir1730 load paper
    Hi,
    I have a ir 1730 that displays load paper A4 even though paper is present in the casette,
    the cassette pick up unit does not move, the casette does not lift . The machine is working right from the manual tray.
    the Size detect unit seems is working right it shows the different types of paper if you move the casette guides.
    does anyone know the problem? pick up unit assembly or dc controler....?
    I look forward to hearing from you soon
    ALL THE BEST
  • ernesto
    • Oct 2011
    • 430
    Re: ir1730 load paper
    Originally posted by ernesto
    Hi,
    [ATTACH=CONFIG]29037[/ATTACH]
    ALL THE BEST
    Hi
    paper pick up assembly was the problem (fm1-b727-010)
    ALL the best
    • MunsterTech
      • Sep 2014
      • 377
      i have seen this on the 1730 and ir400, where the size detect unit has a cable cut or loose, easily replaced and sometimes repairable, i think if the machine is sitting on a small desk, sometimes the cassette can close and cut the cable as its not sitting correctly, seen it about 4 times now.
      • onlyinnewfoundland
        • Apr 2013
        • 235
        I wonder if cable ties are the problem??
        • ernesto
          • Oct 2011
          • 430
          • ernesto
            • Oct 2011
            • 430
            The machone has been fixed.... The pick up assembly was the problem
            • ernesto
              • Oct 2011
              • 430
              it has just happened to me .....
              • ernesto
                • Oct 2011
                • 430
                specifically the engine FM4-6568-000 1 LIFT MOTOR UNIT M9
