C2550 Mac UFR2 Driver install inscructions?
  • Canon345
    • Aug 2025
    I have a Yosemite OS that is something like 10.8 or something version. I am trying to find install instructions for this driver. The mac was recog. and the driver was downloaded and installed. But something is not right. The C2550 is not showing up as an option. Where can I find formal instructions for this new OS please. Thank you.
  • Iowatech
    Not a service manager
    • 3930
    Re: C2550 Mac UFR2 Driver install inscructions?
    It's been years since I've worked on Canon equipment, so this might be nonsense.
    Still, if you haven't tried already, you might check here.
    • Canon345
      I am just going to try it with the guide. I don't know what mac changed and know nothing about these macs. I am still shocked they killed SMB scanning so being unfamiliar with macs is cause to worry!
      • C.Vallon
        • Jan 2015
        • 70
        Don't forget to check the integrity of the driver installed? It may be possible that the driver was corrupted in the download or even in the install.
        Sorry, I'm not much on Mac myself, I find their self righteous limitations and forced user ethics to be a bit dated and harsh. Not to say I wouldn't work with the OS, I just prefer not to.
        • alex@wocltd.com
          • 430
          download and unpack - this install the 'package' ,then system preferences add printer using ip address at bottom of drop down add printer then select 2550 ,should then work......
          as a quick test to check communication before downloading anything use the generic pcl and generate test page - if no good then you havent configured correctly.....
