IR7095 not copying any. white paper comes out.
  • ugaa
    • Mar 2013
    • 26
    Hi, I have a problem that IR7095 not copying any. white paper comes out. cartridge is full. can any one help what is the cause? your help is appreciated
  • teckat
    • 16083
    Re: IR7095 not copying any. white paper comes out.
    Examin the Developer unit, make sure there is toner on the visible area of the Mag Roller
    If no toner visible, unit may not be turning_?
    • ugaa
      • Mar 2013
      • 26
      [Thank you Teckat.
      I checked there is toner but remember the copier is not new. it should always be toner their. Do you think some thing else would cause?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5005
        Rusted coronas?
        • teckat
          • 16083
          [Thank you Teckat.
          is the developer unit turning
          • MrB
            • Nov 2009
            • 147
            Good chance its the drum not turning, and the coupling on the drum is damaged
            Had this a couple of times
            • Brian G
              • Mar 2015
              • 21
              Is your developer bias lead (red wire white connector) plugged into the developer unit? Also like the other tech said make sure the coupler on the front of the drum is positioned correctly and not broken.
              • Iowatech
                Not a service manager
                • 3930
                This might be stupid, as it has been years since I've worked on Canon equipment.
                Still, as ugaa said this only happens when copying, so this is probably more likely an issue with the scanner than any other part of the print engine.
                Hope that helps, and sorry if it was a waste of time.
