ir 5065 white line
  • ernesto
    • Oct 2011
    • 430
    ir 5065 white line
    Hi
    I have a ir 5065 it makes a perfect white line, it is always in the same place... you can see the sample, it has been done in mode test number two.
    The developer unit is plenty of toner it is working right
    does anyone knows the problem?
    I look forward to hearing from you soon
    All the best
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: ir 5065 white line
    Originally posted by ernesto
    Hi
    All the best
    From the pic sample nobody can knows exactly.Only we can guess or give you a hint.
    Looks like developer but it's not necessary.I suggest overview of drum and transfer.Did you make force stop to shrink options? If you have perfect
    image on drum then can be transfer problem. If the line is on the drum image can be drum or primary corona.And of course there is always laser unit or even PCB issue!I believe you already inspect fixing unit.
    I still bet on primary corona and second is developer (Terminal Plate)
    Good luck!
    • ernesto
      • Oct 2011
      • 430
      Good luck!
      you are right zoraldinho the problem was on primary corona
      thanks a lot
      • zoraldinho
        • Mar 2008
        • 5013
