Canon Ir 3030 jam code 10D
  • Kurt
    • 56
    [Jamming] Canon Ir 3030 jam code 10D
    Anyone have this problem, only during duplexing. I've removed the black little dampers that get sticky. Cleaned all rollers. Not sure what it is. Thanks for any guidance. Kurt
  • ernesto
    • Oct 2011
    • 430
    Re: Canon Ir 3030 jam code 10D
    Have you removed all the black dampers that get sticky? there are six of them....
    • ernesto
      • Oct 2011
      • 430
      Hi,
      Here you can see the two hidden dampers, the other four are easier to see. THey are in the delivery frame assembly...
      • Kurt
        • 56
        Originally posted by ernesto
        Hi,
        Thanks, I'll try that. I knew of the four but not six of them. Kurt
        • Brian G
          • Mar 2015
          • 21
          Sometimes removing them can cause issues as well since the diverter gate now sits lower than it should. I usually try and replace the 2 from the diverter gate with some sort of sticky back padding.
