This is a new machine with 1220 copies. Each time you make a copy on auto paper select it selects A3 and call for wrong paper size. Even if you select A4 it says wrong paper selected.How do i make A4 as default.
Canon IRA 4225iInappropriate paper size
Re: Canon IRA 4225iInappropriate paper size
service mode>
in Level 2>COPIER>OPTION>FNC-SW>SENS-CNF> set to "1"
also in
service mode Level 1> COPIER>OPTION>FNC-SW>MODEL-SZ set to "3" will enablethe Document Feeder to correctly identify A4 originals.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
the problem still the same
"the appropriate A4 size is not available"Comment
what do your paper trays read when A4 is loaded in them/ ?
Is this a DF issue or a Glass copy issue /// or from both
UNDER>[Select Paper]
You can select the paper size/type and the paper source.
You can also set the machine to automatically recognize the original size and the copy ratio, and then copy.
What are the switches in Paper Drawer Auto Selection> On/Off in Common in Function Settings (Settings/Registration) set to _
You can set which paper sources can be used for Automatic Paper Selection and Auto Drawer Switching. This setting can be made independently for all functions of the machine, and is especially useful when you want to use different paper sources for different purposes.
- Paper sources set to 'On' are used for the following functions:
- APS (Auto Paper Selection): The machine automatically selects the appropriate paper size (paper source) based on the original's size and copy ratio settings (when making a copy), or the set ratio of the image (when receiving a fax).
- ADS (Auto Drawer Switching): If a paper source runs out of paper during a continuous print job, the machine automatically selects another paper source with the same paper size, and begins feeding paper from that paper source.
Last edited by teckat; 05-22-2015, 09:50 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
