Counter for Long sheet with imagepress c 800
  • khattab.al.masry
    • 212
    [Misc] Counter for Long sheet with imagepress c 800
    Dears all:
    As in title how to determine the counter for long sheet (76cm*33cm) within imagepress c800?
    thanks advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Counter for Long sheet with imagepress c 800
    Like any other Canon copier I believe.Service mode>option>body>user.
    • teckat
      • 16083
      Originally posted by khattab.al.masry
      Dears all:
      thanks advance.
      paper size
      76cm x 33cm
      29.9213 in. x 12.9921 in.
      what counter ?
      software counters for copies/prints
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Yeah - not sure what measurement you're really looking for...
        Anyway, pretty sure this machine is using the ADVANCE system..so if you go into service mode and to go copier > option > custom (i think), you can change your meters...what you're probably looking for is your 102 meter? I guess where you charge a single click or something like that.
        Otherwise check total2 in counter on level1...that'll give you your real count.
        • teckat
          • 16083
          :To set the Counter #1(101) to read 102. First you must go into service mode to enable this function.
          Go to COPIER>OPTION>USER (page 2/7)>CNT-SW set to "1". This will set the first counter from 101 to 102.This will now count 2 clicks for 11x17 and larger sized paper
