Canon 3045 change toner error
  • asser145
    • Mar 2011
    • 40
    I have a canon 3045, calls constantly changing toner
    The machine does not put ready. I have tried several toner and always put toner change.
    I tried another developer assembly machine and keeps asking toner
    anyone knows a solution?
    Tnks
  • Brian G
    • Mar 2015
    • 21
    Re: Canon 3045 change toner error
    First I would say have you tried a DC CON Clear? If so then it sounds like you need a new hopper assembly. Part # FM2-0286-010 You might have to swap the handle from the current one over to the new one. If this does not fix it then you are looking at a DC Controller. Hope this helps, have a good one.
    • asser145
      • Mar 2011
      • 40
      DC CON Clear?
      how it's made ?
      • Brian G
        • Mar 2015
        • 21
        Make sure you have a P-Print or at least the door specs. Service mode lvl 1 copier->function->clear-> highlight DC Con press OK. Do this 2 or 3 times then power cycle machine. re-enter door specs and power cycle again. See if your add toner message goes away. You can try running the Install Toner S as well.
        • ernesto
          • Oct 2011
          • 428
          Tnks
          Hi,
          May be this link can help
          ALL THE BEST
          • asser145
            • Mar 2011
            • 40
            I made the toner-s code several times. but still the same
            I open the toner cover just a little bit to check if the bottle toner is turn around
            • ernesto
              • Oct 2011
              • 428
              If it happens again push the bottle toner out and it fit into the mechanism....it is not uncommon in the older ir 2230 4570.....if the toner bottle is not still around...you can try to do what Brian G says.....
