Canon ir5180 double scan e732-001
  • mramlawi
    • Jul 2011
    • 838
    Dear all,
    i faced a weird problem,i have 2 machines irc5180, one of it 220v and the 2nd 110v,the 220v was working normally,but the 110v was giving error fastly when its booting e748-4878, as i read and ask my friends. They all told me its an main contral problem or lan pcb,some times hdd problem,so i removed all these boards one by one and tried it at the 110v machine also same problem,the parts tooks from 220v ,then i turn all the boards back to the working machine the machine gave e732-001 i changed the values w/scan from 0 to 1 and reverese and same error occur can any one help me in this.
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: Canon ir5180 double scan e732-001
    Originally posted by mramlawi
    Dear all,
    ______________
    Stop double scan=
    SERVICE MODE>COPIER>LEVEL 2>OPTIONS>BODY>SCANSLCT to 0
    Those E codes=
    remove all the sub-boards and clean all the contact pins on the boards and re-install in the Main Controller.
    See pic link.
    https://lh3.googleusercontent.com/dZ...kU3iHBquw=s114
    There is a pub on this , for cleaning & repositioning them.
    See Pub., disregard listed models & errors in pub,
    Cleaning helps.
    • mramlawi
      • Jul 2011
      • 838
      Originally posted by teckat
      ______________
      Stop double scan=
      Those E codes=
      See pic link.
      Cleaning helps.
      https://files.acrobat.com/a/preview/...a-4c961664d6a5
      thank you teckat my problem solved when i connect the 2nd two drawers the error dissapper i wonder how they do in this series if i removed the connecter of the 3rd and 4th drawer the machine give e731-0001
      reagrds,
      • teckat
        • 16083
        reagrds,
        On the imageRUNNER C5185 series the Finisher, the Reader and the Pedestal / Cassette Feed Unit all communicate through the Cassette feeding Unit / Pedestal Controller to the print engine.
        If the print engine looses any communication to any of these accessories one or more of these error codes will occur intermittently.
        UFR PCB error
        E731
        Check the UFR PCB connections
        Reader Communication Error
        E732-0001 = DDI-S communication error >
        Check the connections between the reader controller PCB and main controller PCB. Check the power supply of the reader.
        for some reason this error also effects Cassette Pedestal Power Plug (RE-INSERT)
        Error of the Main Controller PCB
        E748
        -48XX = CPU lock was detected at activation
        Remove and insert the main controller PCB (Sub RB-A). Remove and insert the DDR-SDRAM.
        • mramlawi
          • Jul 2011
          • 838
          UFR PCB error
          E731
          E748
          Thank u again
          but about the 2nd machine 110v which give e748-48 the werid that i changed the sub rb-a baord and still the error occuar abt the DDR-SRam i turned it back when i changed all the main control,should i changed it with the sun rb pcb ??to machine work?
