Modify iR 2380 to iR 3580 - info
  • Garp
    Technical Manager
    • Mar 2015
    • 51
    [Misc] Modify iR 2380 to iR 3580 - info
    Hello everyone,
    I just wonder, did any of ye come accross with the following matter already:
    we deal with end-of-lease machines and I just learnt that some of our customers who buy iR2380 they modify it to iR3580. Not only for consumables, but the speed them up also.
    This doesn't bother us but I only would like to know and understand the procedure.
    What I think is that they re-map the firmware/software but they don't change the hardware.
    Does anyone have any experience with this please?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Modify iR 2380 to iR 3580 - info
    First of all you need cracked sst and routed IRc2380.When you do this please come back for next instructions!
    • Garp
      Technical Manager
      • Mar 2015
      • 51
      Very funny csezdmeg, I don't want to build one (have enough of both), :P only understand how it works to supply them better
      • zoraldinho
        • Mar 2008
        • 5007
        Probably you wont to do something like car chip tuning on Canon machine for better perfomance?
        when you find out please tell me how! Thanks!
        • Garp
          Technical Manager
          • Mar 2015
          • 51
          when you find out please told me how! Thanks!
          Certainly Actually some of our customers does it, and also we know a Canon branch does it in Europe. So some way it can be done for sure. Unfortunatelly I can't ask them straight . That's the reason for this post.
          • teckat
            • 16083
            SPEED
            EXAMPLE > this series has same FIRMWARE
            CiR C3480(i)/C3380(i)/
            C3080(i)/C2880(i)/C2550(i)
            as in this Series , it's the same Firmware
            CiR C5185/5180(i)/C4580(i)/C4080(i)
            they are modifying the DCON files= the.prg file & .ird file
            Some PRG files also contain text files with source code.
            • Garp
              Technical Manager
              • Mar 2015
              • 51
              Well, I got an answer but I feel this a bit narrow.
              It was told, that the following procedure stands for both 3 relations: iR2880 -> iR3380, iR2380 -> iR3580, iR3080 -> iR3580.
              So it was told that the only thing you have to do is to copy the content of the LC46 chip of the Serial Board and the 24C64 chip of the Counter Board to the slower machine AND have an RA board fitted. Plus you have to change back the Serial Number in the chip after copying.
              They swear it works.
              Would this be all only?!
              • teckat
                • 16083
                Bottom Line
                dont' know where u live , but it's against the law to manipulate the Serial Board ( as in going to Jail )
                Canon has copyright protected control on all Serial Boards in all of their products.
                Serial Number PCB is a matched board with the Counter Memory PCB and cannot be swapped
                with any other equipment. Doing so will generate an E354 or E355 code.
                The Counter Memory PCB is electronically stamped with the serial number from the Serial Number PCB.
                -Counter Memory PCB is no longer a restricted part.
                -Serial Number PCB's will continue to be restricted. The Serial Number PCB can only be obtained by
                contacting the Canon Technical Support Hotline.
                Counter Memory, Serial Number and Main Controller PCBs work as a set.
                In Color Products it's the ECO ID PCB that continues to be restricted.
                Counter Memory PCB, ECO ID PCB and SRAM PCB retain information pertinent to the specific engine they are
                installed in. Ensure that you never swap any of these circuit boards with another engine.
                Counter Memory PCB, ECO ID PCB and SRAM PCB communicate information with the Main Controller.
                Counter Memory PCB is a matched board with the ECO ID PCB and cannot be swapped with one from any other engine.
                • Garp
                  Technical Manager
                  • Mar 2015
                  • 51
                  teckat: as I wrote it above I have no intention to do this. As I said it is more for my curiosity. (Please read it above.)
                  • teckat
                    • 16083
