TR7200 machine with finisher sorting problem
  • Dis
    • Mar 2011
    • 35
    Hi all, as title, my friend machine was a problem on IR7200, when the machine sort with finisher offset collect,
    the first copy will be sort on tray A, and the second set will sort at tray B,
    and continue, all 1,3,5,7,9 copies sort at tray A, and 2,4,6,8,10 sort at tray B,
    this cause machine running very slow,
    4 unit of machine having the same issue, and the same of exchange between 4 of the finisher.
    please help, which setting can solve this issue?
  • Dis
    • Mar 2011
    • 35
    Re: TR7200 machine with finisher sorting problem
    Sorry, it is IR7200.....
    • teckat
      • 16083
      Network Print or Walkup Copying_?
      Look at print driver.
      • Dis
        • Mar 2011
        • 35
        Hi Teckat, just normal copy with sort.
        • teckat
          • 16083
          so u walk up to Printer and drop a set of documents into DF tray to Sort >?
          The machine sends sheets from the copier to tray A or tray B, according to the selected mode of delivery, and performs job offset, stapling or punching in accordance with commands
          from the copier.
          Job Offset
          • Dis
            • Mar 2011
            • 35
            from the copier.
            Job Offset
            Yes, just walk up to machine and drop a set of document to copy at ADF, and sort.
            1st, 3rd, 5th, 7th all sort at tray A
            2nd, 4th, 6th, 8th all sort at tray B
            Still with Offset at B tray......
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5002
              What happens when "collate and offset" set to off?
              • teckat
                • 16083
                Mystery
                Tray A/Tray B
                Copied/Printed paper is output to Tray A (upper) when the number of copy/print sets is 1,or when no
                collate modes are set.
                Collated copies/prints are output to Tray B (lower).
                *You can assign the trays to be used for either the copy or printer function.
                *Collated copies/prints can also be output to Tray A when it is set as a dedicated tray.
                Capacity Per Tray
                [Non-Collate Mode]
                TrayA
                11" x 17", LGL, LTR, LTRR, and STMTR: 5-3/4" (147 mm) (equivalent to 1,000)
                TrayB
                LTR, LTRR: 11-1/4" (285 mm) (equivalent to 2,000)
                11" x 17", LGL: 5-3/4" (147 mm) (equivalent to 1,000)
                [Collate Mode]/[Group Mode]
                TrayA
                TrayB
                [Staple Mode]
                TrayA
                11" x 17", LGL, LTR, and LTRR: 100 sets or 5-3/4" (147 mm)(equivalent to 1,000)
                TrayB
                LTR, LTRR: 100 sets or 11-1/4" (285 mm) (equivalent to 2,000)
                11" x 17", LGL: 100 sets or 5-3/4" (147 mm) (equivalent to 1,000)
                [Non-Collate/Collate/Group/Staple mode] with different paper sizes
                • Dis
                  • Mar 2011
                  • 35
                  Mystery
                  Tray A/Tray B
                  Capacity Per Tray
                  [Non-Collate Mode]
                  TrayA
                  TrayB
                  TrayA
                  TrayB
                  [Staple Mode]
                  TrayA
                  TrayB
                  Hi tecket, thanks a lot for your information, the problem solved after send back to supplier.
                  the problem is due to wrong model of finisher, supplier send wrongly,
                  it is IR 550 finisher......just change a finisher will do
                  • zoraldinho
                    • Mar 2008
                    • 5002
                    • teckat
                      • 16083
