E000110-0000 in canon ir 7095
  • hari_4848
    • Jul 2008
    • 91
    [Error Code] E000110-0000 in canon ir 7095
    Hello
    attached is pic of error im facing.
    help appreciated
    thanks
  • lilleputte
    • Jan 2013
    • 154
    Re: E000110-0000 in canon ir 7095
    E110 The laser scanner motor rotation has a fault.
    0000 After the laser scanner motor has gone on, the PLL lock signal of the motor is
    not detected
    for 15 sec or more.
    Check to see if all covers have been attached to the primary
    charging assembly. Disconnect
    and then connect J764 of the laser scanner motor drive PCB
    (in the laser scanner unit).
    Disconnect and then connect J1401 of the video PCB.
    Disconnect and then connect J506 of
    the DC controller PCB. Replace the laser scanner unit.
    Replace the video PCB. Replace the
    DC controller PCB
