Canon Ir 3300
  • simonchin
    • May 2015
    • 22
    [Error Code] Canon Ir 3300
    I got error code problems with Canon IR 3300 from E0002 to E0009 which mean after I cleared
    with one error code I can made few print or copied then error code show up with difference number,
    any idea, please help
  • alan
    • Mar 2008
    • 40
    Re: Canon Ir 3300
    try to check the fixing unit... fixing film could be the problem..
    • teckat
      • 16083
      Re: Canon Ir 3300
      a defective SW3 switch can cause an E002 error code.The part number for the switch is WC8-5178-000
      Door switch (SW3Cuts AC power to fixing heater, Cuts 24V power to main motor, fixing
      motor, composite power supply PCB
      also make sure Power Supply (Switching Regulator) ver. is not -(01) & at least (02)
      see pdf
