IRadv 6255
  • MunsterTech
    • Sep 2014
    • 381
    [Jamming] IRadv 6255
    hi,
    Still having issues with the Right hand deck lifting paper. The paper select shows sometimes that the paper is loaded, however the lifting plate in the stock assy has not lifted at all. I have now changed the Sensor assy and lifting motor for the Right hand deck, swapped the paper stock assy, dumped the DC controller and even swapped the DC but still the same that paper is not lifting up to the pick up assy.
    Am I missing something? is there a driver pcb or something?? lost and confused!
  • teckat
    • 16083
    Re: IRadv 6255
    Originally posted by MunsterTech
    hi,
    Paper Deck Height Sensor_? > Check change of state in service mode.
    Deck lifter cable wire_?
    ?_So > sometimes you get a lift.
    ?_Without paper do u get "add paper" on a lift.
    ?_Deck Harness.
    • MunsterTech
      • Sep 2014
      • 381
      Re: IRadv 6255
      hi,
      ive tried a new right hand paper deck or stock assy for a better word, makes no difference either. when there is no paper at all in the deck, it can say its full, even though the lifting plate is down on the bottom of the deck...ive changed the sensor assy at the back, FM4-0931-000, deck remnant detect assy and the lifting motor for the right hand deck...still the same, dc controller has been changed and settings set back in service mode....still shows paper full even when no paper is present and lifting plate is down
      • teckat
        • 16083
        Re: IRadv 6255
        hi,
        So both Right Side Decks(one swapped in) exibt same exact problem_?
        ?_ when u open right deck, Does printer show to close it_?
        • MunsterTech
          • Sep 2014
          • 381
          Re: IRadv 6255
          yep, paper deck swapped and exhibits same problem, pick up assy swapped still the same, if i open the deck shows no paper present so i guess the sensor is working, but that has been replaced too. if i close the deck with paper in it, it says no paper, because its not lifted, if i turn the machine off and on, when powered up, shows paper present even though lifting plate is at the bottom of the deck. if i press for a copy, will jam because of the paper not lifted...very strange
            Re: IRadv 6255
            This may help
            Affected by static charge, the paper level sensor erroneously detects the existence of paper when no paper exists, and
            so feeding operation is executed and that leads to a jam.
            deck.pdf
            • teckat
              • 16083
              Re: IRadv 6255
              OK !!
              So sensors are working, but not in a normal sense========
              Feed Driver PCB
              PCB3
              Right Deck Lifter Motor- M04
              J225
              PIN 1-SIGNAL
              PIN2-GD
              Did u check I/O (I/O display mode)
              P015
              P015
              BIT
              15 -Right Deck Pickup Sensor 1/2 PS19 = 1: Paper presence
              14 -Right Deck Pickup Solenoid Connection SL6 =0: Connect, = 1: Not connect or Driving
              13 -Right Deck Paper Height Sensor PS6 = 0: Lifter Up
              12 -Vertical Path Sensor 2 PS25 = 1: Paper presence
              11 -Vertical Path Sensor 3 PS26 = 1: Paper presence
              10 -Right Deck Upper Limit Sensor PS8 = 1: Upper limit
              9 -Vertical Path Cover Open/Close Sensor PS2 = 0: Open
              8 -Right Deck Pull Out Sensor PS32 = 1: Paper presence
              7 -For R&D use -
              6 -For R&D use -
              5 -For R&D use -
              4 -For R&D use -
              3 -Right Deck Paper Level Sensor 2 PS48 _Detect paper level by combination of the Paper Level Sensor 1/2=0: OFF=1: ON (Condition that the flag blocks the sensor)
              2 =Right Deck Paper Level Sensor 1 PS47_Detect paper level by combination of the Paper Level Sensor 1/2=0: OFF=1: ON (Condition that the flag blocks the sensor)
              As for the combination, refer to the Pickup/Feed System in Service Manual.
              1 =Right Deck Lifter Motor M4 = 1: Error
              0 =Right Deck Paper Sensor PS7 =0: Paper absence, =1: Paper presence
              Did u run a Controller System Error Diagnosis
              1) Turn ON the Main Power Supply Switch while pressing the numeric keys '2' and '4'
              simultaneously
              2) Keep pressing the numeric keys (for approx. 20 seconds) until the following screen appears
              on the Control Panel.
              • MunsterTech
                • Sep 2014
                • 381
                Re: IRadv 6255
                tks for that teckat, havent tried the system check for errors, is that just for the DC or every board?? illl check the I/O next time im there, i was pulled off the job to do something else as i was about to strip it down to check the wiring..but hopefully should be back there on Weds...mite have more time to check it all out...its a weird one
                • MunsterTech
                  • Sep 2014
                  • 381
                  Re: IRadv 6255
                  Originally posted by skynet
                  This may help
                  [ATTACH]29343[/ATTACH]
                  is that at the rear of the deck the 2 sensors? ive actually replaced the whole assy, seems to be the main issue is that the lifting plate is not lifting..even though the sensors would say that paper is present even though its not lifted up...weird ...
