Canon C7000VP Error Code 0271-05
  • theprintshop
    • Jun 2015
    • 15
    I keep getting this error code E 000001-0271-05 every time I turn on my machine. I cannot find this error code ANYWHERE. Please help
    - THEPRINTSHOP
  • teckat
    • 16083
    Re: Canon C7000VP Error Code 0271-05
    - THEPRINTSHOP
    Codes updated in imagePRESS C7010VP Manual
    E001-0271= Error in abnormally high temperature of fixing assembly.
    0x71=Error: software detection of abnormally rising temperature at external heat upper roller sub thermistor.
    When the external heat upper roller sub thermistor detects the temperature that exceeds the specified value (primary/secondary: 245 deg C) for 1 sec continuously.
    x=
    1: Primary fixing
    2: Secondary fixing
    External heat upper roller thermistor:
    THM302(primary fixing),THM307(secondary fixing)
    Fixing heater driver PCB: UN306(primary fixing), UN307(secondary fixing)
    Fixing external driver PCB: UN304(primary fixing), UN305(secondary fixing)
    Fixing duplexing feed driver PCB: UN311
    DC controller PCB 1-2: UN124
    Procedure Checks
    1. Check for any caught harnesses. => Replace them if necessary.
    - external heat upper roller sub thermistor
    - between the external heat upper roller sub thermistor and the fixing external driver PCB
    - between the fixing external driver PCB and the fixing duplexing feed driver PCB
    - between the fixing duplexing feed driver PCB and the DC controller PCB 1-2
    2. Check that the external heat upper roller sub thermistor is clean and properly installed. => Clean and reinstall it if necessary.
    3. Replace the following parts if necessary.
    - external heat upper roller thermistor
    - fixing heater driver PCB
    - fixing external driver PCB
    - fixing duplexing feed driver PCB
    - DC controller PCB 1-2
    -When turning ON the power, be sure to turn ON the power in the following order: pickup/delivery accessories -> Main Body: Otherwise the pickup/
    delivery accessories are not recognized.
    execute ERR:
    COPIER > FUNCTION > CLEAR > ERR. The error is cleared by turning OFF and then ON the power after ERR execution.
