Canon IRC2100 Problem
  • salim
    I will be very grateful if any one can help me to know what the code E810-0202 mean in a color copier canon IRC2100
  • JustManuals
    • Jan 2006
    • 9838
    The photosensitive drum unit is faulty.
    Paul@justmanuals.com
    • Gamut
      • Jul 2008
      • 216
      E810
      Main cause The Photosensitive Drum Unit is faulty.
      Condition of
      detection
      XX=01: Y, XX=02: M, XX=03: C, XX=04: Bk (XX indicates the developing
      assembly color)
      XX01 The Photosensitive Drum Unit is absent.
      XX02 The wrong Photosensitive Drum Unit is mounted (wrong color).
      XX03 The Photosensitive Drum is wrongly installed (wrong country
      model).
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        hallo dear salim this is solution of code E810 in ir copieurs :The case that the toner bottle is detected, but not the cartridge. Main cause: The DC controller PCB is faulty. The cartridge is faulty.
        Action :
        1. High-voltage contact (between machine and the developing unit): Is the high-voltage spring used to supply high voltage to the developing unit soild?
        YES: Clean it.
        2. High-voltage contact (between high-voltage spring and DC controller PCB; J207): Is the connection between the high-voltage spring and the DC controller PCB(J207) normal?
        NO: Correct the connection.. If the problem cannot be corrected, re-place the faulty part.
        3. Developing unit, DC controller PCB: Replace the developing unit. Is the problem corrected?
        YES: End
        NO: Replace the DC controller PCB
        BEST TECHNICIAN . NICE PEOPLE .
        • salim
          Thanks for all who gave me part of thier time on replying to me
