Hello,
Regarding Canon Imagepress C1 ,
I attached one scanned print.
There are a set of four points generated by the machine visible on each print .
The four points are one Cyan , one Magenta , one Cyan and one Yellow.
After I changed the drum unit , two months ago ,the sets of points diapers.
I did not printed more than 200 prints in the meantime , using the new drum unit.
A Canon tech from my country told me that the set of 4 points appears when the drum unit is close to his life cycle.
Can some one tell me if there is a technical Bulletin from Canon about this problem?
Do you have more information about this problem.
Best Regards,
Adrian
Best Regards,
Adrian
