Hi Guys,
Need some help. I have a canon c5235 with stapler unit. whenever i print say 500 copies, there is no problem. However, if I print 500 sets of 2 pages with collate and staple settings turned on, the output tray does not move down much.
I can only print about 30 sets and the printer would show error " Output tray is full, please remove paper". However, the output tray never move much. If I print a job about 4 or 5 sheets with stapling function, then only about 10 over sets will be done and the tray is again full. After removing the paper, the printer will continue the job.
Is it a setting issue? Why the output tray is full after only 100 or 150 sheets? If i just print normally, I can get the output tray to fill 500 to 1000 sheets easily before the output tray is full error appears.
Any input is greatly appreciated.
Thanks for reading
Thanks for reading
