Canon IR 1600 fixing unit problems
  • spree
    • Jun 2012
    • 211
    Hello, I have problem with Canon IR 1600. 3/4 of the paper (at the begining) has text fixed, but 1/4 (at the end) is not fixed - when you put your finger on text you can smudge the text. Do you have any idea what to change: pressure roller, fixing roller, halogen heater or thermistors?
    Why is 3/4 fixed and 1/4 is not fixed?
    Thank you very much.
  • Blizzoo
    • Aug 2013
    • 608
    Re: Canon IR 1600 fixing unit problems
    Worn out heat roller bushings, change them first.
    • dan7777
      • Dec 2012
      • 680
      I would replace the fixing unit. Expensive I think but last time I tried to order thermistors they were not available. I think you would have to take the fuser unit out to figure out why some of the text was fused. I used to leave those fusers alone until I had a problem. Not a fan of the removal.
      • spree
        • Jun 2012
        • 211
        When I take out the fixing unit and the pressure and fixing rollers will be in good condition, you think the thermistors are bad?
        I see (without take out the fixing unit) that the pressure roller is in good condition, but some text was on it!
        • spree
          • Jun 2012
          • 211
          Maybe good idea, but the machine has 80.000 pages printed, but is 10 - 15 years old
          • spree
            • Jun 2012
            • 211
            Please could you detaily discribe me this:
            "I used to leave those fusers alone until I had a problem."
            Do you think thermistors instead fusers?
            Thanx.
