ir105+
  • tomcatt
    • Jul 2010
    • 91
    [Electrical] ir105+
    Customer with 105+ with a m3 controller.Customer is able to print small pdf jobs with no problems as well as large copy jobs. When printing a large pdf of 600 double sided prints the screen on the copier will go blank and turn back on.no error code .I suspect the controller....
  • teckat
    • 16083
    Re: ir105+
    Enter service mode select COPIER>FUNCTION>SYSTEM>CHK-TYPE>select 1 and press O.K. Next select HD-CLEAR and select O.K.
    The machine should display Start then O.K! Cycle the main power switch.
    The machine will clear sector 1, which is the image storage area.
    & check
    256 MB memory/ Remove both > clean end> re-seat or replace --------WA7-3294-000
