CANNON GP160
  • Ptosh
    CANNON GP160
    Hi, I have a cannon gp160 and it has a scanner but I cant find any cable port to connect the photocopy/scanner machine. Can you assist on how I can connect my cannon gp160 to my computer windows xp
    • 16083
    Re: CANNON GP160
    Canon Gp160 Ethernet Board Pcb Assembly (nid-1.5 Board)
    Canon GP160 ETHERNET BOARD PCB ASSEMBLY (NID-1.5 Board)
    • Ptosh
      Re: CANNON GP160
      HOW CAN I CONNECT Canon Gp160 Ethernet Board Pcb Assembly (nid-1.5 Board) ON THE CANON GP160 AND HOW DOES IT LOOK LIKE AFTER IT HAS BEEN CONNECTED PLEASE
        • 16083
        Re: CANNON GP160
        Did you look on side of unit to see if u already have a connection_?.
        If not_ u need to purchase, and install inside unit.
        • Ptosh
          Re: CANNON GP160
          I have installed the inside unit and the side of my canon GP160 is completely sealed such that I cant add anything unless i cut it off, how will I install the Canon Gp160 Ethernet Board Pcb Assembly (nid-1.5 Board) on the machine.
