[Canon C5051] Procedure for Cleaning Patch Sensor
  • cswake
    • Jan 2012
    • 28
    My machine has come up with three "Check the printer. Call service representative." errors in the past few days. Specifically, the unit has shown error E020 / 0081 and E020 / 104 codes. The P-LED-DA value is 63, so I am hoping that cleaning the patch sensor window will solve it. Could someone tell me the procedure?
  • teckat
    • 16092
    Re: [Canon C5051] Procedure for Cleaning Patch Sensor
    The shutter needs to open to allow the Patch Sensors to read the image patch on the ITB. The Shutters main prupose is to minimize dusting on the Patch Sensors.
    The movement of the Shutter is controlled by SL1 ( Registration Shutter solenoid ) and can be activated via Parts Check in Service Mode.
    See link pdf
    Note: The Shutter Linkage does not have a part number. You must order the Pattern Read Shutter Drive Assembly FM3-8902-000. See FIG. 321 of the Parts Catalog.
    E020 0104 error code on display.
    Solution :
    Replace patch sensor unit and black drum.
    Part numbers as follows: Patch Sensor Unit=FM3-5944-010, GPR-30 Black Drum - 2776B004BA, GPR-31 Black Drum - 2778B004BA
    Initialization of patch sensor is necessary. COPIER>OPTION>IMG-MCON>P-ALPHA>Input Patch Sensor alpha value.
    • chinxxx
      • Jun 2015
      • 35
      Thanks, in advance, for any info.
      Very interesting. thanks for sharing.
      รวดเร็วก่อนใคร ระดับคุณภาพเรื่องฟุตบอล ได้ที่นี่ ฟุตบอลสด
      • hidius
        • Jun 2015
        • 128
        also check that the shutter itself hasnt come off the solenoid
        • cswake
          • Jan 2012
          • 28
          The shutter works fine and after testing it and manually moving it back and forth a few times, the copier has worked for two days without issue. Do you guys recommend that I should proactively replace the Pattern Read Shutter Drive Assembly since the current one seems to bind/jam?
          • cscce
            • Jun 2014
            • 156
            Replace the assembly. I had a c5030 with the same problem. The patch sensor appeared to be working fine yet the machine threw patch sensor related errors every day or two. Eventually the linkage broke and I had to replace the assembly. The problem has not returned after several months.
            • cswake
              • Jan 2012
              • 28
              Assembly was ordered. Thanks for the feedback. On a side note, for anyone seeing this thread in the future, the procedure for cleaning the patch sensor is section 4-89 of the service manual:
