Canon IR3750 Leading Edge Problem
  • daniboi
    End User
    • Oct 2009
    • 42
    Gentlemen,
    I got this leading edge 1.6 inches away from the edge of the paper on Canon IR3570
    I tried to fix it in service mode but did not worked, it just narrowed a little.
    I found the clutch(CL2) very dirty, and cleaned it, but also didn't helped.
    Can you please help me find my way out of this.
    respectfully,
    daniboi
  • hidius
    • Jun 2015
    • 128
    Re: Canon IR3750 Leading Edge Problem
    Replace the registration clutch
    • MunsterTech
      • Sep 2014
      • 380
      I agree if you are getting movement like that, replace the registration clutch and should solve the issue.
      • Canuck
        Tech Specialist
        • 1713
        How many copies on machine? The registration sensor actuator wears down on these and will actuate late. A rusty reg clutch will cause this also. If it is slipping, the paper will be late and cut the top of the image off. Never had to change a reg clutch on one of these
        • daniboi
          End User
          • Oct 2009
          • 42
          Thanks everybody,
          True, the problem is the registration clutch. I cleaned it the first time
          but not thoroughly cleaned. Now I cleaned it real good, spinning smoothly. It's working.
          One thing I learned, Clutches don't really break easily, they're just become dirty and needs cleaning
          sometimes. Don't throw that away.
