iPF 8000s black misaligned
  • bat
    • Sep 2008
    • 140
    Hi all...
    I having this problem for quite some time now, only black color is misaligned (it is a 8 color printer) other colors are fine. It is a vertical misaligment. Printer cannot complete auto or manual head adjustment. I have already replaced printheads, cariage and flat cable, main board is tested on a other printer so it is working fine. I am realy stumped with this problem. When printing unidirectional, vertical lines look better but not as sharp as other colors.scan.pdf
  • V-P
    • Apr 2011
    • 679
    Re: iPF 8000s black misaligned
    print a nozzle check and upload it here
    • bat
      • Sep 2008
      • 140
      Thanks innozzle12.pdf advance..
      • V-P
        • Apr 2011
        • 679
        Left head has issues and need to be replaced.
        If the head is new and is showing this problem after a short time than you need to inspect purge unit and carefully check tubing from end to end for any leak.
        • bat
          • Sep 2008
          • 140
          Thanks for reply, I have raplaced purge unit from a working printer this morning still no result...tubes dont have leeks that i can see, only thing that I didnt raplaced is toner tank unit. Can this unit have leaks inside that can couse presure loss in tubes?
          • V-P
            • Apr 2011
            • 679
            The chances are that by replacing print head (with a NEW one) you will solve the problem.
            • bat
              • Sep 2008
              • 140
              The printhead now present in printer is a third NEW printhead that I have replaced since problem started, so I have ruled out printhead.
              • V-P
                • Apr 2011
                • 679
                Are you using OEM ink ?
                • bat
                  • Sep 2008
                  • 140
                  Soory for not posting but I was on vacation, and my problem was waiting for me. Recently we have started using non OEM ink. Im sending a pic of container. I contacted the manufacturer and he says that the ink cannot be the cause of the problem.
