Dear All ,
i have a really weird problem made me mad , the problem when i use the ADF for Canon ir2016 the copy paper exit cutting the line from the right side , also when i use the Glass i noticed that its also cutting a little bit comparing with the original on the lass .
what i did
1:i changed the feeder with no result also i use the same feeder on other machine and it works fine .
2:i have try to make a copy using the Bypass also no result
3:i changed the registration clutch also same proble,
4:i have change the ccd and the scanner board
5:i have change a main board
6:i changed the value on the service mode ssw-numaric-41 it was 0 i put it 35 a little bit change but still cutting the line
the figure below no1 how its was when i try the feeder , figure no1 the original one , figure no3 after changing the values of 41/42 1.JPG2.JPG3.JPG
any suggestion is theres anything must do !?
what i did
