Ir7105 Paper Pick Up Deck Issue
  • sunboi
    • Dec 2011
    • 34
    Hi Guys,
    I have an issue with the paper pick up for Ir7105.
    After replacing the HDD, the copier prompt load paper. Paper was loaded in the Right Deck and i can see the paper has been lifted. However, the machine didnt detect the papers.
    After reading the post http://www.copytechnet.com/forums/ca...out-paper.html
    i did a check on the Sens-Adj and CL-Adj but all was NG
    for OP-SENS, the result was all NG for all trays.
    The paper was set correctly in the CST.
    Wonder is there any additional advise on where to find the fault on?
  • tinnyjay
    • Oct 2009
    • 663
    Re: Ir7105 Paper Pick Up Deck Issue
    Originally posted by sunboi
    Hi Guys,
    Before 2-3 months a had the same problem with cst 4.
    I had to change paper feed unit because cleaning and changing sensors was not the key.
    "Who loves the roses,must also bear thumbs"
    • teckat
      • 16083
      Check the state of PS22 in I/O Mode, P004-8. PS22 is the Deck Right Paper Sensor which detects the paper in the right deck.
      If P004-8 indicates a "1", it is assumed to have paper in the deck
      PS22 connects to the DC Controller @ J511.
      Try re-seating the J511 connector at the DC Controller.
      • spectraindo
        • May 2008
        • 313
        In Service Mode, check COPIER>OPTION>CST>P-SZ-C1 for Right Deck ,the values should be 6 for A4,15 for B5 or 18 for LTR paper size.
        Other values may display there is no paper in the deck.
