Re: Firmware for imagePress server T1
i don't find T1 reboot into the server configuration,
I have C1+ with T1 and i nedd change the french language too.
into touch display i prees -> and i select the botton "printer option" for entering into the T1 menu
i press function and i have 2 page
in the second page i have configuration and inside "server configuration" but i don`t see rebbot.
You can show me the step please
thank so much
yes --> add. functions - common Settings - language switchLeave a comment:
the t1 servers come with 2 CD containing the system software. if you restore the server from the CD it will give you an option to select language at the start of the setup processLeave a comment:
Thanks disam, that worked.
Is there a way to change the language on the C1 itself? I mean on the main screens...Leave a comment:
try this, but it will erase all data on T1
at the MFP Screen - Printer - Printer - Function- Server Setup - T1 reboot - Login in - valeur d'utilisateur - oui, after this it reboot and now you can Change the language.Leave a comment:
Hi guys.
Does anyone know where i could get the firmware for the T1 server?
I could not find it on canons website.
I got one T1 connected to a imagePress C1 and there is french language installed...i would like to have it in english.Tags: None
