image pass B2
  • roho
    • Mar 2009
    • 844
    [Misc] image pass B2
    During a print run the color tends to shift. I haven't seen any patches that address this issue, and it appears to only occur during a print run, the engine seems fine. Wondering if anyone else has had issues with this fiery server, or if the system software might need to be re installed. Any thoughts or sugesstions would be greatly appreciated. I've addressed the engine and cleaned all the lasers, and performed all the autograd and calibrations.
  • teckat
    • 16083
    Re: image pass B2
    Shift_?
    Paperfeed_?
    or Crossfeed_?
    Single or Two sided_?
    Or both ways.
    Does PG6 show shift_?
    Go in and remove B2 calibration.
    Then calibrate Printer> then the Fiery.
    • roho
      • Mar 2009
      • 844
      Re: image pass B2
      Sorry, the entire output has a gradual shift in colour, from the first print of a set compared to the later outputs, same file, long run. The customer has been doing the autograds and calibrations, as I had also after cleaning the lasers for lines. The prints themselves look fine, side to side, front and back, however there is a difference from the first to last print, although each print itself is even throughout itself. Hope this clarifies, thanks!
      • teckat
        • 16083
        Re: image pass B2
        So you mean color gradation / saturation starts off OK!!> then is not constant throughout the finish run
        how do u calibrate the B2 ????
        Color quality is not consistent
        File or application problem--
        1. Print a different color test page from another application.
        2. If the quality of the test page is good, there may be a file or application problem.Out of calibration or calibration information/ curves on the active
        partition are corrupted--
        1. If you suspect that a custom calibration setting is causing the problem, reset the calibration setting to its default measurements:
        In Command WorkStation > Device Center > General > Tools, click Manage.
        Calibrator opens.
        In Calibrator, select the calibration setting that you suspect is causing the problem, and then click View Measurements.
        Click Reset to Default Measurements, and then click Yes to confirm.
        If resetting to default calibration does not solve the problem, you may need to service the copier.
        2. If restoring default measurements fixes the color quality, the custom calibration may have been the cause of the problem. Request that the site
        administrator recalibrate the imagePASS. For details, see Color Printing,
        which is part of the user documentation set.
        3. If the problem persists after recalibration, the calibration information on the hard disk drive may be corrupt. Reinstall system software.
        4. If the problem persists, the hard disk drive may be corrupt. Verify that all hard disk drive cabling is correct.
        5. If hard disk drive cabling is correct, you may need to replace the hard disk drive.
        Spot Color Matching
        When Spot Color Matching is set to On, banding (visible steps between the shades in a color gradient) or bands of color that are missing altogether might result in the printed image. Also,
        if you print separations, pages might be printed in color, instead of black and white. These undesirable effects depend on the application. As a workaround, set Spot Color Matching
        to Off.
        Resolution print option
        When Adobe Illustrator pattern tiles are applied to a large area of a job's object, a part of the object might not print correctly with Resolution set to 1200dpi. In this case, set Resolution to
        600dpi.
        ImageViewer Color Adjust
        • roho
          • Mar 2009
          • 844
          Re: image pass B2
          Thanks, I will be following up when I get a chance, busy these days.
          • roho
            • Mar 2009
            • 844
            Re: image pass B2
            Went over all the chips and pcbs, reseated and cleaned the image pass out, and reloaded system software a week ago. The customer hasn't called back, seems as though this was the fix for this issue, thanks for your help!
            • Canuck
              Tech Specialist
              • 1713
              Re: image pass B2
              Clean the patch sensors. They are used for setting color registration along with reading density. Make sure the shutter isn't broken. Very common. Usually if color registration is wandering or colors are poor/changing.. the patch sensors are dirty
              • teckat
                • 16083
                Re: image pass B2
                U never know > Miracles do happen !!!!!!!!!!
