IRadvC 33xx series
  • MunsterTech
    • Sep 2014
    • 381
    [Misc] IRadvC 33xx series
    Hi guys n gals,
    On a days course next week to learn about the new IRadvC 33xx series machines, that I persume Canon have introduced to bypass the crappy IRadvC 2200 series etc.
    Just looking to see if anyone has worked on these yet, is there much difference to the 20/2200 series, better hopefully....any info gratefully received to give me a bit of a heads up before going there.
    tks
  • disam
    • Sep 2008
    • 64
    Re: IRadvC 33xx series
    Hi
    i have two of this devices, the device does not make any bad Impression, easy to install and also very easy to Change the ITB, Fixing unit, Drum and Toner. The paper Cassette one ist only a A4 Cassette, the rest of the place, left side, there you find the waste toner bottle.
    But the biggest Change is, the Login, new it is with Administrator and 76543231, and you have a lot of possibility to set users with rights.
    The RSOK is also Standard on this device.
    • alex@wocltd.com
      • 430
      we've had to cancel our courses as too busy over the next couple of months what with holiday cover etc...
      boxes appear to be okay still very plastic so only time will tell, can't tell if its still this pulverised dev/toner combo either
      biggest ballache has been the default security.....it wont let you use isend without being within the domain and approved - fine for large multinationals but an utter pain initially for our smaller clients......
      have found various things to allow but would prefer a setting within service mode to either have enhanced security or not
      • wassem
        • Aug 2012
        • 166
        Originally posted by disam
        Hi
        i think there is some miswriting
        the admin default password is still 7654321 (there is no 3 before 1)
