Horizontal lines from IR c3380
  • LucasN
    • Feb 2014
    • 11
    Looking for a second opinion on the attached image.
    Background: used a non-canon toner and began seeing lighter images. Figured that is just something to do with the toner and ignored it, we just ran copies darker (btw it printed from PC fine, it was just copies). Now I have started to see these horizontal lines at the top of my pages. Thinking the issues are unrelated. Regrading the lines, I took the unit open vacuumed it out a bit, which helped for a small period of time, like 50 copies. I'm thinking drum issue, but I was hoping someone here may be able to confirm that before we spend the money on it.
    Thank you,
    LN
  • copydocinc
    • Mar 2015
    • 263
    Re: Horizontal lines from IR c3380
    If this doesn't happen when printing and only happens when you copy. The only possibility is the optics.
    • LucasN
      • Feb 2014
      • 11
      Point of clarity: the lightness issue does not happen when printing, only when copying. The horizontal lines happen all the time, printing or copying.
      • hidius
        • Jun 2015
        • 128
        does the lightness happen when you copy of the ADF and the glass ?
        • copydocinc
          • Mar 2015
          • 263
          I'm gunna have to agree with you and say the drum unit also.
          • LucasN
            • Feb 2014
            • 11
            It's present in either copies, adf or flat glass, and prints as well.
