code erro E012-0500 en imagePRESS C800
  • Joseph2011
    • Aug 2011
    • 88
    good
    I have a problem with one imagePRESS C800 is the error code is E0012-0500 I reviewed the transfer unit but prints a few leaves and comes out the error code and also leaves calibrate the equipment or the band with trnasferencia (INIT- ITB)
    regards
  • teckat
    • 16083
    Re: code erro E012-0500 en imagePRESS C800
    Originally posted by Joseph2011
    good
    regards
    Color Displacement / Pitch Lines at Regular Interval (120 mm /60 mm) /
    & E012-050x Error Codes
    see attach pdf
    -ITB Drive Motor drive detection error
    Harnesses from the Drum ITB Driver PCB to the ITB Drive Motor■[Points to note at work] When checking the harness/cable or connector, perform the following work.■
    1. Disconnect and then connect the connector to check that there is no bent pin and cable disconnection.■
    2. Visually check that the harness is not caught or open circuit.■
    3. If there is any error, replace the corresponding harness/cable.■
    [Remedy] Check/replace the related parts.
    • Joseph2011
      • Aug 2011
      • 88
      see attach pdf
      good morning
      please thanks for the help I have reviewed the transfer assembly but at the time of setting INIT- ITB passes without any problem but when wanting to print out the error code again E012-0500
      alcanse some more out of this problem
      regards
      • teckat
        • 16083
        good morning
        regards
        did u check the connections listed
        did u read the attached pdf
