iR 1023 IF Auto-continue is not working for T2.
  • MFPTech
    • 486
    If there is 1 sheet of paper left in T1 and try to make 2 copies the machine will feed the first sheet and will jam without even trying to pull the paper from T2 - phantom jam. checked all the settings in Additional functions and they all look good.
    Printing individually from each tray works fine.
    Will do a firmware update but in the meantime thought to check here if anybody had this problem before or has any ideas.*
    Thanks in advance!*
  • disam
    • Sep 2008
    • 64
    Re: iR 1023 IF Auto-continue is not working for T2.
    Hi
    any jam code?
    • MFPTech
      • 486
      Good question. Did not check; don't like those small tiny screen machines
      • MFPTech
        • 486
        the jam is 0104 pick up delay jam - Reg sensor SR11 does not detect the leading edge. As i said in my OP everything is fine if Trays are selected manually. Did the firmware update - still no change.
