looking procedure to replace the hard disk in ir adv 6255
  • gksapple
    • Apr 2014
    • 116
    [Misc] looking procedure to replace the hard disk in ir adv 6255
    can any one send me the procedure to replace hard disk in ir adv 6255?
  • teckat
    • 16083
    Re: looking procedure to replace the hard disk in ir adv 6255
    HDD
    1. Before Replacing
    Perform the following operations. Be sure to get an approval from the user beforehand.
    1) Backup of the set/registered data
    Use the Remote UI2) Printing the set/registered data
    Use the service mode
    (under Level 1) COPIER > FUNCTION > MISC-P > USER-PRT
    List of the set/registered data which cannot be backed up is printed.
    2. After Replacing
    1) HDD format
    1-1) Start with the safe mode. (While pressing 2 and 8 keys simultaneously, turn ON the main power switch.)
    1-2) Use SST to format all partitions.
    2) Downloading system software
    2-1) Use SST to download the system software (System, LANG, RUI and others).
    3) Initializing the key, certificate and CA certificate
    (under Level 2 in Service Mode) COPIER > FUNCTION > CLEAR > CA-KEY
    4)
    Turning OFF and ON the main power switch
    5) Restoring the backup data
    Use the Remote UI
    Management Settings > Data Management > Import/Export
    6) Resetting/registering the data
    While referring to the list of set/registered data which was printed before replacement, reset/register the data.
    7) When the user generates and adds the encryption key, certificate and/or CA certificate, request the user to generate them again.
    8)
    Settings/Registration mode: Adjustment/Maintenance > Adjust Image Quality > Auto Adjust Gradation
    NOTE:
    When using the Card Reader and imageWARE Accounting Manager
    Card ID used for imageWARE Accounting Manager is stored in the HDD, so NSA collection control is not enabled after the HDD replacement.
    After the HDD is replacedCAUTION: Points to Caution when Using the System Software-installed HDD
    When using the HDD which was installed the system software of the other machine (different serial number), be sure to format the HDD after the installation. If the HDD is
    not formatted, the operation cannot be guaranteed.
    • gksapple
      • Apr 2014
      • 116
      * actual problem in this machine is e602-002;
      *finished the format by following sm i got e-740-2012
      *after replaced hdd
      *formatted by using sst but machine is not booting more than 4 hours
      *still it showing formatting
      kindly help me to sort it out
      • teckat
        • 16083
        *after replaced hdd
        shut it down / does not take 4 hours/
        what ver. of firmware ??
        where did u get this HDD ??
        • gksapple
          • Apr 2014
          • 116
          *shutdown and formatted the hard disk issue resolved
          thanks a lot
          • teckat
            • 16083
            thanks a lot
            all about keeping it simple
            • Gleq
              • Feb 2007
              • 72
              Its so true
              • Gleq
                • Feb 2007
                • 72
                hello
                please am still waiting for help on the firmware or sst ver 4.72
                cheers
                • tommy81
                  how can i got firmware for ir adv 6255. i have problem with harddisk
