E025-04B0 in history and would not allow toner change. Cut ties wire harness not avai
  • Canon345
    • Jul 2025
    [Error Code] E025-04B0 in history and would not allow toner change. Cut ties wire harness not avai
    Reboot didn't work. Service called, Opened up the door via cont. panel, install new toner. Problem gone for now.
    Solution was found in tech data. PS8 in the black hopper is not changing state when the toner bottle rotates. Problem has been solved by cutting wire ties. The wire harness that causes the problem is FM3-8929-010.
    To my surprise I was told that the part has been on backorder since 2013. Can anyone add any color to this? I would like to have a spare harness or a couple new ones. This is the Set on drive Black mount assembly.
    I am going to check PC for info about the other colors too.
  • teckat
    • 16083
    Re: E025-04B0 in history and would not allow toner change. Cut ties wire harness not
    FM3-8929-010--------------10/12.00 online
    • Canuck
      Tech Specialist
      • 1713
      E020 gear.JPGWhat product? 7000 series? Changed a quite a few cracked one-way gears on these....black and color hopper assemblies
