We are getting this error code. I cannot find what the problem is. Please help. -thanks
Canon C7000VP Error Code 000260-1000-05
Tags: None
Re: Canon C7000VP Error Code 000260-1000-05
The error was E260 with a sub code of 0001.
You could encounter other sub codes. The wires going to J7751D may be loose and the pin 11 wire may be caught by the process cover cam latch for the the drum heater switch when re_installing the cover.
 Secure the harness with wire ties as indicated before the problem develops.
Re picture links👀
https://lh3.googleusercontent.com/SO...blUr5LC7R=s106
https://lh3.googleusercontent.com/YY...0ZZ_MGgQeK=s85
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Problem :
Re picture links👀
E260=1000/ Sorry miss read the sub-code
10xx Error: 24V, 12V power supply Unit-type 24V/12V error other than 24V power supply errors
When detecting the error signal for 500msec (100msec x 5 times) consecutively when the power was turned on.
00= Developing high-voltage PCB (Bk)
E260-1000 is defined as 12V/ 24V power supply error to the Black Developer HVT. (UN136).
UN136 receives 24 VDC from the Main Station Power Supply Relay Board (UN102).
SEE THIS ATTACHED PDF ----E260-1000 Error
**** this pinch wire is probably not your issue
Process Unit Cover=====
Open the main station front right cover and the main station front left cover .
Remove the 2 stepped screws [1], shift the 3 levers [2] and the lever (small) [3] in the direction of the arrow in order . While holding the 2
grips [4], remove the process unit cover [5].
process cover cam latch for the the drum heater switchAttached FilesLast edited by teckat; 07-03-2015, 04:43 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
