I am working on a Canon IR 5070 chargeable and this all started with a call for E0001-0010. I reset the code, cleaned it up, tested and noticed it was offline so I put it back online. Everything OK. 15 days later I got a call for a fuser entrance jam ( about 4 sheets ), it also had the E0001-0010 code again. After clearing the jam and resetting the code I COULD NOT get the machine to go back online. I checked the error code history and Found these codes in this order one right after the other reading from the top down,
E0001-0010, E0732-0001, E0733-0001, E0674-000C, then it repeats this time ending with E0001-0002, then repeats one more time.
I do not know what the service history was before I started working on it and the meter is 1,150K.
I do not have a manual for this model yet and if the cost for repair is too much the customer will likely not fix it.
From my research it looks like I'm looking at a total fuser rebuild or upper fixing unit ( FM2-9733-000 ??? ) and possibly a Main PCB and or DC Controller ( cannot find part #'s for the boards ). Any help and part numbers would be greatly appreciated.
