I have a I/R 7105 under contract that when coping or printing from any paper source and using 8.5 by 11 paper copies/prints its almost perfect.
When using 14" paper there is a void band going across the top and its quite light down the left side . I scanned each but the 14' other than showing the void area at the top doesn't show much down the side. We have changed the fuser, transfer assembly, charge wires...basically everything....but in our books if the 11" is perfect so should the 14"....makes no sense...11" paper is fed wide edge and even with narrow edge it makes no difference...14' naturally is short edge only
Sample A is the 14" paper and B is the 11" paper
