2520 print is not having contrast in rainy days
  • pulkit jain
    • Dec 2012
    • 73
    sir i am facing the problem that my ir 2520 is not giving the contrast print in rainy days what type special mode i use to make the print good
    please tell me the function of special modes in adjustment cleaning option.
    it is urgent
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: 2520 print is not having contrast in rainy days
    it is urgent
    High humidity environment! I presume the degradation in the print quality is not accompanied with paper curling or jamming, in which case you may need to try using fresh paper from the wrapper since the one in the cassettes might have absorbed humidity, or use the special mode 'N'.
    Otherwise, use special mode 'M' to solve any issue with irregularity in print density. This mode 'M' select the machine's transfer output from three levels; standard, low and high.
    To enter this mode: Press the ADDITIONAL FUNCTION key repeatedly until 'special mode M' appears. Press 'M'. Press the up/down arrow to select the desired output level, in this case 'HIGH', PRESS 'OK', press the RESET button to return to normal screen.
    Enjoy good quality copies.
    • Peter Sim
      • Sep 2008
      • 445
      I was wondering how you enter special mode 'M'
      From your post said "press the additional key repeatedly untill special mode appear",but i fail to enter the mode.
      Can you let me know the sequence again?Is not in the service manual?
      • teckat
        • 16083
        In some operating environments, it may become difficult for the toner to become fixed on the paper.
        Special Mode G can solve this problem by reducing the print speed, thus allowing more time for the toner to become fixed on the paper. This mode is useful especially when printing on heavyweight or lightweight paper.
        NOTE - The default setting is Off.
        1. Press (Additional Functions) > [Adjustment/Cleaning].
        2. Press up or down until [Special Mode G] appears. Press [Special Mode G].
        3. Press [On] or [Off] to enable or disable the mode . Press [OK].
        The selected mode is set.
        NOTE - If Special Mode G is set to On, printing may become slower.
        4. Press (Reset) to return to the top screen.
          • Oct 2010
          • 860
          Sorry i missed one of the steps in the sequence: Additional function > Adjustment/cleaning> up & down arrow
          > special mode M > select [HIGH] > OK. Follow 'teckat's step' but selecting the mode [M] instead of mode [G].
          • teckat
            • 16083
            Image Transfer Wrong/Text Void
            [Cause]
            Resistance of paper increases due to reduction in paper water content, resulting in insufficient
            transfer output.
            Resistance of paper decreases due to increase in paper water content, resulting in excessive
            transfer output.
            [Occurrence condition]
            Paper left alone in a low-humidity environment
            Paper left alone in a high-humidity environment[Remedy]
            USER MODE
            > Adjustment/ Cleaning> Special Mode M> Low or High
            • Peter Sim
              • Sep 2008
              • 445
              Thank you
              • Peter Sim
                • Sep 2008
                • 445
                [Cause]
                transfer output.
                transfer output.
                USER MODE
                [ATTACH=CONFIG]29865[/ATTACH]
                Thank you,very useful info
                  • Oct 2010
                  • 860
                  it is urgent
                  Hey pulkit jain, you posted a question you claim was 'URGENT', you got some urgent replies, but you have now gone 'underground'...(mute). say something, tell the forum if our suggestions were helpful to you or not, so that others may benefit from it.
