2380i LCD problem
  • fatfingers73
    • Feb 2013
    • 219
    [Misc] 2380i LCD problem
    Morning all,
    After some advice with this fault (pic attached).
    Parts guide lists 3 different LCD's for this control panel, and a complete unit is worth more than the machine!
    Thanks in advance
  • teckat
    • 16083
    Re: 2380i LCD problem
    Originally posted by fatfingers73
    morning all,
    after some advice with this fault (pic attached).
    Parts guide lists 3 different lcd's for this control panel, and a complete unit is worth more than the machine!
    Thanks in advance
    C3580/3580i/3480/3480i/3080/3080i/2550/2550i/2380i
    there is only one LCD listed ?
    #2 / fc5-4458-010 sheet, lcd electrostatic
    #5 / fk2-0329-000 analog touch panel unit
    #6 / fm4-6149-000 lcd control panel unit
    • tbudic
      • Mar 2014
      • 2
      Hi, having same problem with my 3080i
      But I am confused with part numbers.
      Is this the same part : Canon IR2270 IRC2880 IRC3080 etc LCD Control Panel Unit FY6 0455 FH6 0806 | eBay
      it says control panel unit for 3080i, but it is not the same part number as you wrote.
      thanks
      Tomislav
      • tbudic
        • Mar 2014
        • 2
        Hi, I have the same problem with my irc3080i.
        But I m litlle confused with part numbes you wrote.
        Is this: Canon IR2270 IRC2880 IRC3080 etc LCD Control Panel Unit FY6 0455 FH6 0806 | eBay
        Can I use it on my irc3080i.
        It says in description that is for irc3080 also.
        thanks
        Tomislav
