Getting regular 0107 jams, I've replaced the rollers, and the fuser including the guides, even the right door. The device will function for a couple of days and start jamming again, I've checked over everything that I can think of. Has anyoner else had a stubborn jam issue with this device, I've loaded the most recent firmware version available.
4245 advance
Re: 4245 advance
Getting regular 0107 jams, I've replaced the rollers, and the fuser including the guides, even the right door. The device will function for a couple of days and start jamming again, I've checked over everything that I can think of. Has anyoner else had a stubborn jam issue with this device, I've loaded the most recent firmware version available. -
Re: 4245 advance
any error codes pop in service mode menu at same times listed for jam codes ??
I would go Replace the CL3, the Registration clutch
what is paper type ?? good or cheap ?**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
