Canon Ir 3035 Delay Jam 010A
  • tibbs
    • Aug 2008
    • 223
    Hello friends,
    I have a customer with a canon Ir3035 thats jamming when making duplex copies.
    The jam code is 010A sensor PS4A.
    Can anyone shade some light on this jam.
    Dont seem to see any thing in the paper path.
    Thanks in advance.
  • teckat
    • 16083
    Re: Canon Ir 3035 Delay Jam 010A
    Originally posted by tibbs
    Hello friends,
    Thanks in advance.
    010A Jam only While Duplexing.
    jam can be caused by the tab on the second delivery flapper being damaged or broken, preventing the flapper from operating correctly. The part number for the flapper is FC5-1003-040.
    • tibbs
      • Aug 2008
      • 223
      Thanks much Teckat, for the information, but its not the tabs I have checked it out and its not damage or broken.
      What else can possibly cause this jam?
      • Canuck
        Tech Specialist
        • 1713
        Remove the black rubber dampers in behind the flapper......they cause it to stick
        • ernesto
          • Oct 2011
          • 430
          Hello friends,
          Thanks in advance.
          it could be useful
          • tibbs
            • Aug 2008
            • 223
            Thanks people, but its not the black tabs either, can any other thing cause this.
            • teckat
              • 16083
              Change the door💵
              • Canuck
                Tech Specialist
                • 1713
                Does it jam every time or intermittently? Delivery to inner tray/finisher or right side delivery?All paper sources and sizes? Is paper registered properly? I have seen cases where plain paper(20 lb.) is registered as heavy,causing it to curl massively(especially this time of year with high humidity here) after printing the first side. The curl causes it to jam when reversing to do the 2nd side. Something to look at...
                • anubansal
                  • Mar 2022
                  • 1
                  i have the same problem in machine what solution you used for it tell mee
